Time Before: 0.02722 seconds
Time After: 0.03271 seconds
Time Taken: 0.00549 seconds
Time Before: 0.03284 seconds
Time After: 0.03322 seconds
Time Before: 0.03345 seconds
Time After: 0.03364 seconds
Time Before: 0.03443 seconds
Time After: 0.03714 seconds
Time Taken: 0.00271 seconds
Time Before: 0.03369 seconds
Time After: 0.04130 seconds
Time Taken: 0.00761 seconds
Time Before: 0.05095 seconds
Time After: 0.05134 seconds
Time Before: 0.05293 seconds
Time After: 0.05420 seconds
Time Before: 0.05015 seconds
Time After: 0.05448 seconds
Time Taken: 0.00433 seconds
Time Before: 0.08771 seconds
Time After: 0.08786 seconds
Time Before: 0.13879 seconds
Time After: 0.14007 seconds
End call of global.php: 0.14223909378052
Time Before: 0.15238 seconds
Time After: 0.15252 seconds
Time Before: 0.15462 seconds
Time After: 0.15636 seconds
Time Taken: 0.00174 seconds
SET lastactivity = 1784796743, location = '/forums/private.php?do=newpm&explain=1&u=6387'
Time Before: 0.17340 seconds
Time After: 0.17365 seconds
Memory Before: 4,911.164 KB
Memory After: 4,911.383 KB
Page generated in 0.17244100570679 seconds with 9 queries, spending 0.0084834098815918 doing MySQL queries and 0.1639575958252 doing PHP things.
