Time Before: 0.02954 seconds
Time After: 0.04009 seconds
Time Taken: 0.01055 seconds
Time Before: 0.04018 seconds
Time After: 0.04065 seconds
Time Before: 0.04091 seconds
Time After: 0.04105 seconds
Time Before: 0.04188 seconds
Time After: 0.04497 seconds
Time Taken: 0.00309 seconds
Time Before: 0.04110 seconds
Time After: 0.05035 seconds
Time Taken: 0.00925 seconds
Time Before: 0.06163 seconds
Time After: 0.06209 seconds
Time Before: 0.06547 seconds
Time After: 0.06925 seconds
Time Taken: 0.00377 seconds
Time Before: 0.06077 seconds
Time After: 0.06949 seconds
Time Taken: 0.00872 seconds
Time Before: 0.11362 seconds
Time After: 0.11376 seconds
Time Before: 0.13827 seconds
Time After: 0.13987 seconds
Time Taken: 0.00160 seconds
Time Before: 0.14807 seconds
Time After: 0.14890 seconds
Time Taken: 0.00082 seconds
Time Before: 0.15209 seconds
Time After: 0.15517 seconds
UPDATE session SET lastactivity = 1785404822, location = '/forums/private.php?do=newpm&explain=1&u=63919', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.17371 seconds
Time After: 0.17401 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
