Time Before: 0.01953 seconds
Time After: 0.02700 seconds
Time Taken: 0.00748 seconds
Time Before: 0.02710 seconds
Time After: 0.02758 seconds
Time Before: 0.02781 seconds
Time After: 0.02795 seconds
Time Before: 0.02881 seconds
Time After: 0.03127 seconds
Time Taken: 0.00247 seconds
Time Before: 0.02804 seconds
Time After: 0.03664 seconds
Time Taken: 0.00860 seconds
Time Before: 0.04329 seconds
Time After: 0.04354 seconds
Time Before: 0.04614 seconds
Time After: 0.04736 seconds
Time Before: 0.04236 seconds
Time After: 0.04759 seconds
Time Taken: 0.00523 seconds
Time Before: 0.06726 seconds
Time After: 0.06740 seconds
Time Before: 0.31473 seconds
Time After: 0.31599 seconds
End call of global.php: 0.31810998916626
Time Before: 0.32477 seconds
Time After: 0.32505 seconds
Time Before: 0.32774 seconds
Time After: 0.33009 seconds
Time Taken: 0.00235 seconds
SET lastactivity = 1784815180, location = '/forums/private.php?do=newpm&explain=1&u=63927', badlocation = 1
Time Before: 0.34747 seconds
Time After: 0.34779 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.34610390663147 seconds with 9 queries, spending 0.0089085102081299 doing MySQL queries and 0.33719539642334 doing PHP things.
