Time Before: 0.00153 seconds
Time After: 0.00220 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00226 seconds
Time After: 0.00268 seconds
Time Before: 0.00296 seconds
Time After: 0.00314 seconds
Time Before: 0.00400 seconds
Time After: 0.00635 seconds
Time Taken: 0.00235 seconds
Time Before: 0.00321 seconds
Time After: 0.00977 seconds
Time Taken: 0.00656 seconds
Time Before: 0.01212 seconds
Time After: 0.01254 seconds
Time Before: 0.01517 seconds
Time After: 0.01637 seconds
Time Before: 0.01141 seconds
Time After: 0.01662 seconds
Time Taken: 0.00521 seconds
Time Before: 0.02458 seconds
Time After: 0.02478 seconds
Time Before: 0.02728 seconds
Time After: 0.02848 seconds
End call of global.php: 0.030779123306274
Time Before: 0.03212 seconds
Time After: 0.03229 seconds
Time Before: 0.03460 seconds
Time After: 0.03603 seconds
SET lastactivity = 1782998663, location = '/forums/private.php?do=newpm&explain=1&u=63972', badlocation = 1
Time Before: 0.05306 seconds
Time After: 0.05340 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.051923990249634 seconds with 9 queries, spending 0.0078952312469482 doing MySQL queries and 0.044028759002686 doing PHP things.
