Time Before: 0.00128 seconds
Time After: 0.00176 seconds
Time Before: 0.00184 seconds
Time After: 0.00232 seconds
Time Before: 0.00250 seconds
Time After: 0.00265 seconds
Time Before: 0.00328 seconds
Time After: 0.00611 seconds
Time Taken: 0.00284 seconds
Time Before: 0.00270 seconds
Time After: 0.00949 seconds
Time Taken: 0.00679 seconds
Time Before: 0.01140 seconds
Time After: 0.01184 seconds
Time Before: 0.01436 seconds
Time After: 0.01559 seconds
Time Before: 0.01071 seconds
Time After: 0.01587 seconds
Time Taken: 0.00516 seconds
Time Before: 0.02104 seconds
Time After: 0.02123 seconds
Time Before: 0.02317 seconds
Time After: 0.02449 seconds
Time Taken: 0.00132 seconds
Time Before: 0.02726 seconds
Time After: 0.02746 seconds
Time Before: 0.02946 seconds
Time After: 0.03089 seconds
UPDATE session SET lastactivity = 1789108628, location = '/forums/private.php?do=newpm&explain=1&u=64014', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04363 seconds
Time After: 0.04395 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
