Time Before: 0.00201 seconds
Time After: 0.00259 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00270 seconds
Time After: 0.00328 seconds
Time Before: 0.00349 seconds
Time After: 0.00364 seconds
Time Before: 0.00440 seconds
Time After: 0.00661 seconds
Time Taken: 0.00221 seconds
Time Before: 0.00368 seconds
Time After: 0.01003 seconds
Time Taken: 0.00635 seconds
Time Before: 0.01190 seconds
Time After: 0.01235 seconds
Time Before: 0.01548 seconds
Time After: 0.01674 seconds
Time Before: 0.01128 seconds
Time After: 0.01694 seconds
Time Taken: 0.00567 seconds
Time Before: 0.02183 seconds
Time After: 0.02195 seconds
Time Before: 0.02395 seconds
Time After: 0.02581 seconds
Time Taken: 0.00186 seconds
Time Before: 0.02882 seconds
Time After: 0.02896 seconds
Time Before: 0.03105 seconds
Time After: 0.03250 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=64015', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.04733 seconds
Time After: 0.04768 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
