Time Before: 0.00153 seconds
Time After: 0.00219 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00229 seconds
Time After: 0.00278 seconds
Time Before: 0.00301 seconds
Time After: 0.00318 seconds
Time Before: 0.00387 seconds
Time After: 0.00631 seconds
Time Taken: 0.00244 seconds
Time Before: 0.00323 seconds
Time After: 0.00972 seconds
Time Taken: 0.00649 seconds
Time Before: 0.01154 seconds
Time After: 0.01196 seconds
Time Before: 0.01442 seconds
Time After: 0.01560 seconds
Time Before: 0.01096 seconds
Time After: 0.01578 seconds
Time Taken: 0.00483 seconds
Time Before: 0.02081 seconds
Time After: 0.02101 seconds
Time Before: 0.02294 seconds
Time After: 0.02416 seconds
End call of global.php: 0.026371002197266
Time Before: 0.02752 seconds
Time After: 0.02769 seconds
Time Before: 0.03028 seconds
Time After: 0.03170 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=64087'
Time Before: 0.04553 seconds
Time After: 0.04596 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.044605016708374 seconds with 9 queries, spending 0.0081613063812256 doing MySQL queries and 0.036443710327148 doing PHP things.
