Time Before: 0.01607 seconds
Time After: 0.01983 seconds
Time Taken: 0.00376 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.01994 seconds
Time After: 0.02042 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02069 seconds
Time After: 0.02084 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02151 seconds
Time After: 0.02392 seconds
Time Taken: 0.00241 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02089 seconds
Time After: 0.02775 seconds
Time Taken: 0.00686 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.03192 seconds
Time After: 0.03232 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.03503 seconds
Time After: 0.03619 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.03130 seconds
Time After: 0.03640 seconds
Time Taken: 0.00510 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.05797 seconds
Time After: 0.05810 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.09959 seconds
Time After: 0.10087 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
Time Before: 0.13045 seconds
Time After: 0.13064 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.13491 seconds
Time After: 0.13637 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=6410', badlocation = 1 WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.15839 seconds
Time After: 0.15865 seconds
Memory Before: 5,997.719 KB
Memory After: 5,997.938 KB
