Time Before: 0.03120 seconds
Time After: 0.03727 seconds
Time Taken: 0.00607 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.03741 seconds
Time After: 0.03787 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.03813 seconds
Time After: 0.03828 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.03919 seconds
Time After: 0.04145 seconds
Time Taken: 0.00226 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.03837 seconds
Time After: 0.04614 seconds
Time Taken: 0.00777 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.05250 seconds
Time After: 0.05285 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.05598 seconds
Time After: 0.05819 seconds
Time Taken: 0.00220 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.05179 seconds
Time After: 0.05847 seconds
Time Taken: 0.00667 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.10484 seconds
Time After: 0.10504 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.17169 seconds
Time After: 0.17291 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
Time Before: 0.20161 seconds
Time After: 0.20174 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.20591 seconds
Time After: 0.20738 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=64134', badlocation = 1 WHERE sessionhash = 'c9ecef9835dff112a7666634a7a1b42a'
Time Before: 0.23684 seconds
Time After: 0.23710 seconds
Memory Before: 5,997.742 KB
Memory After: 5,997.961 KB
