Time Before: 0.01913 seconds
Time After: 0.02833 seconds
Time Taken: 0.00920 seconds
Time Before: 0.02840 seconds
Time After: 0.02882 seconds
Time Before: 0.02904 seconds
Time After: 0.02918 seconds
Time Before: 0.02996 seconds
Time After: 0.03245 seconds
Time Taken: 0.00249 seconds
Time Before: 0.02925 seconds
Time After: 0.03719 seconds
Time Taken: 0.00794 seconds
Time Before: 0.04489 seconds
Time After: 0.04531 seconds
Time Before: 0.04710 seconds
Time After: 0.04834 seconds
Time Before: 0.04402 seconds
Time After: 0.04854 seconds
Time Taken: 0.00452 seconds
Time Before: 0.08243 seconds
Time After: 0.08256 seconds
Time Before: 0.25937 seconds
Time After: 0.26083 seconds
End call of global.php: 0.26307106018066
Time Before: 0.27294 seconds
Time After: 0.27311 seconds
Time Before: 0.27591 seconds
Time After: 0.27737 seconds
SET lastactivity = 1785369904, location = '/forums/private.php?do=newpm&explain=1&u=6417'
Time Before: 0.29734 seconds
Time After: 0.29859 seconds
Memory Before: 4,288.281 KB
Memory After: 4,288.500 KB
Page generated in 0.29623198509216 seconds with 9 queries, spending 0.0092029571533203 doing MySQL queries and 0.28702902793884 doing PHP things.
