Time Before: 0.02789 seconds
Time After: 0.03441 seconds
Time Taken: 0.00652 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.03453 seconds
Time After: 0.03522 seconds
Time Taken: 0.00069 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.03552 seconds
Time After: 0.03569 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.04048 seconds
Time After: 0.04327 seconds
Time Taken: 0.00279 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.03577 seconds
Time After: 0.04759 seconds
Time Taken: 0.01182 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.05854 seconds
Time After: 0.05893 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.06149 seconds
Time After: 0.06269 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.05787 seconds
Time After: 0.06291 seconds
Time Taken: 0.00504 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.11251 seconds
Time After: 0.11268 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.13822 seconds
Time After: 0.13952 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
End call of global.php: 0.1415810585022
Time Before: 0.15021 seconds
Time After: 0.15039 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.15283 seconds
Time After: 0.15444 seconds
Time Taken: 0.00161 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=64382'
Time Before: 0.17519 seconds
Time After: 0.17547 seconds
Memory Before: 4,918.352 KB
Memory After: 4,918.594 KB
Page generated in 0.17426109313965 seconds with 9 queries, spending 0.0087714195251465 doing MySQL queries and 0.1654896736145 doing PHP things.
