Time Before: 0.00155 seconds
Time After: 0.00203 seconds
Time Before: 0.00210 seconds
Time After: 0.00250 seconds
Time Before: 0.00268 seconds
Time After: 0.00282 seconds
Time Before: 0.00379 seconds
Time After: 0.00604 seconds
Time Taken: 0.00225 seconds
Time Before: 0.00287 seconds
Time After: 0.01118 seconds
Time Taken: 0.00832 seconds
Time Before: 0.01416 seconds
Time After: 0.01490 seconds
Time Taken: 0.00074 seconds
Time Before: 0.01844 seconds
Time After: 0.01973 seconds
Time Before: 0.01340 seconds
Time After: 0.02001 seconds
Time Taken: 0.00662 seconds
Time Before: 0.02695 seconds
Time After: 0.02709 seconds
Time Before: 0.02965 seconds
Time After: 0.03091 seconds
End call of global.php: 0.032619953155518
Time Before: 0.03391 seconds
Time After: 0.03416 seconds
Time Before: 0.03658 seconds
Time After: 0.03805 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=64411', badlocation = 1
Time Before: 0.05162 seconds
Time After: 0.05193 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.050565958023071 seconds with 9 queries, spending 0.0082271099090576 doing MySQL queries and 0.042338848114014 doing PHP things.
