Time Before: 0.02672 seconds
Time After: 0.03024 seconds
Time Taken: 0.00352 seconds
Time Before: 0.03036 seconds
Time After: 0.03094 seconds
Time Taken: 0.00059 seconds
Time Before: 0.03120 seconds
Time After: 0.03133 seconds
Time Before: 0.03210 seconds
Time After: 0.03453 seconds
Time Taken: 0.00243 seconds
Time Before: 0.03139 seconds
Time After: 0.03845 seconds
Time Taken: 0.00706 seconds
Time Before: 0.04637 seconds
Time After: 0.04678 seconds
Time Before: 0.04916 seconds
Time After: 0.05039 seconds
Time Before: 0.04571 seconds
Time After: 0.05057 seconds
Time Taken: 0.00486 seconds
Time Before: 0.09146 seconds
Time After: 0.09165 seconds
Time Before: 0.18863 seconds
Time After: 0.18984 seconds
End call of global.php: 0.19209098815918
Time Before: 0.20188 seconds
Time After: 0.20207 seconds
Time Before: 0.20468 seconds
Time After: 0.20621 seconds
Time Taken: 0.00152 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=64507', badlocation = 1
WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.22670 seconds
Time After: 0.22707 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.22564697265625 seconds with 9 queries, spending 0.0082681179046631 doing MySQL queries and 0.21737885475159 doing PHP things.
