Time Before: 0.00140 seconds
Time After: 0.00190 seconds
Time Before: 0.00197 seconds
Time After: 0.00239 seconds
Time Before: 0.00256 seconds
Time After: 0.00267 seconds
Time Before: 0.00336 seconds
Time After: 0.00566 seconds
Time Taken: 0.00230 seconds
Time Before: 0.00271 seconds
Time After: 0.00911 seconds
Time Taken: 0.00640 seconds
Time Before: 0.01096 seconds
Time After: 0.01130 seconds
Time Before: 0.01371 seconds
Time After: 0.01500 seconds
Time Before: 0.01035 seconds
Time After: 0.01517 seconds
Time Taken: 0.00482 seconds
Time Before: 0.02007 seconds
Time After: 0.02020 seconds
Time Before: 0.02205 seconds
Time After: 0.02327 seconds
End call of global.php: 0.024965047836304
Time Before: 0.02658 seconds
Time After: 0.02673 seconds
Time Before: 0.02955 seconds
Time After: 0.03101 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=64553', badlocation = 1
Time Before: 0.04784 seconds
Time After: 0.04818 seconds
Memory Before: 4,911.938 KB
Memory After: 4,912.164 KB
Page generated in 0.046489953994751 seconds with 9 queries, spending 0.0077633857727051 doing MySQL queries and 0.038726568222046 doing PHP things.
