Time Before: 0.02393 seconds
Time After: 0.03325 seconds
Time Taken: 0.00932 seconds
Time Before: 0.03334 seconds
Time After: 0.03376 seconds
Time Before: 0.03398 seconds
Time After: 0.03411 seconds
Time Before: 0.03499 seconds
Time After: 0.03742 seconds
Time Taken: 0.00243 seconds
Time Before: 0.03417 seconds
Time After: 0.04226 seconds
Time Taken: 0.00809 seconds
Time Before: 0.05024 seconds
Time After: 0.05066 seconds
Time Before: 0.05400 seconds
Time After: 0.05544 seconds
Time Before: 0.04955 seconds
Time After: 0.05571 seconds
Time Taken: 0.00616 seconds
Time Before: 0.10886 seconds
Time After: 0.10902 seconds
Time Before: 0.12747 seconds
Time After: 0.12884 seconds
Time Taken: 0.00137 seconds
Time Before: 0.13843 seconds
Time After: 0.13860 seconds
Time Before: 0.14108 seconds
Time After: 0.14253 seconds
UPDATE session SET lastactivity = 1783185365, location = '/forums/private.php?do=newpm&explain=1&u=6457', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.16443 seconds
Time After: 0.16526 seconds
Time Taken: 0.00084 seconds
Memory Before: 4,912.180 KB
Memory After: 4,912.391 KB
