Time Before: 0.00090 seconds
Time After: 0.00133 seconds
Time Before: 0.00137 seconds
Time After: 0.00179 seconds
Time Before: 0.00202 seconds
Time After: 0.00215 seconds
Time Before: 0.00267 seconds
Time After: 0.00473 seconds
Time Taken: 0.00207 seconds
Time Before: 0.00218 seconds
Time After: 0.00661 seconds
Time Taken: 0.00443 seconds
Time Before: 0.00798 seconds
Time After: 0.00839 seconds
Time Before: 0.01125 seconds
Time After: 0.01279 seconds
Time Taken: 0.00154 seconds
Time Before: 0.00748 seconds
Time After: 0.01299 seconds
Time Taken: 0.00551 seconds
Time Before: 0.01803 seconds
Time After: 0.01816 seconds
Time Before: 0.02003 seconds
Time After: 0.02144 seconds
End call of global.php: 0.023195028305054
Time Before: 0.02446 seconds
Time After: 0.02462 seconds
Time Before: 0.02665 seconds
Time After: 0.02810 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=64683'
WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.04056 seconds
Time After: 0.04090 seconds
Memory Before: 4,911.656 KB
Memory After: 4,911.898 KB
Page generated in 0.039663076400757 seconds with 9 queries, spending 0.0080525875091553 doing MySQL queries and 0.031610488891602 doing PHP things.
