Time Before: 0.00321 seconds
Time After: 0.00372 seconds
Time Before: 0.00378 seconds
Time After: 0.00428 seconds
Time Before: 0.00454 seconds
Time After: 0.00468 seconds
Time Before: 0.00573 seconds
Time After: 0.00858 seconds
Time Taken: 0.00285 seconds
Time Before: 0.00476 seconds
Time After: 0.01381 seconds
Time Taken: 0.00906 seconds
Time Before: 0.01637 seconds
Time After: 0.01699 seconds
Time Taken: 0.00062 seconds
Time Before: 0.02089 seconds
Time After: 0.02210 seconds
Time Before: 0.01553 seconds
Time After: 0.02235 seconds
Time Taken: 0.00682 seconds
Time Before: 0.02974 seconds
Time After: 0.02988 seconds
Time Before: 0.03279 seconds
Time After: 0.03409 seconds
End call of global.php: 0.037286043167114
Time Before: 0.03880 seconds
Time After: 0.03899 seconds
Time Before: 0.04249 seconds
Time After: 0.04395 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=64724'
Time Before: 0.05764 seconds
Time After: 0.05790 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.056390047073364 seconds with 9 queries, spending 0.0086467266082764 doing MySQL queries and 0.047743320465088 doing PHP things.
