Time Before: 0.00137 seconds
Time After: 0.00195 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00202 seconds
Time After: 0.00243 seconds
Time Before: 0.00266 seconds
Time After: 0.00279 seconds
Time Before: 0.00347 seconds
Time After: 0.00572 seconds
Time Taken: 0.00225 seconds
Time Before: 0.00284 seconds
Time After: 0.00965 seconds
Time Taken: 0.00681 seconds
Time Before: 0.01145 seconds
Time After: 0.01192 seconds
Time Before: 0.01445 seconds
Time After: 0.01569 seconds
Time Before: 0.01086 seconds
Time After: 0.01594 seconds
Time Taken: 0.00508 seconds
Time Before: 0.02174 seconds
Time After: 0.02187 seconds
Time Before: 0.02513 seconds
Time After: 0.02643 seconds
End call of global.php: 0.028966188430786
Time Before: 0.03041 seconds
Time After: 0.03057 seconds
Time Before: 0.03321 seconds
Time After: 0.03477 seconds
Time Taken: 0.00156 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=64735'
Time Before: 0.05000 seconds
Time After: 0.05025 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.049074172973633 seconds with 9 queries, spending 0.0079047679901123 doing MySQL queries and 0.041169404983521 doing PHP things.
