Time Before: 0.02201 seconds
Time After: 0.03151 seconds
Time Taken: 0.00949 seconds
Time Before: 0.03162 seconds
Time After: 0.03205 seconds
Time Before: 0.03232 seconds
Time After: 0.03249 seconds
Time Before: 0.03323 seconds
Time After: 0.03632 seconds
Time Taken: 0.00309 seconds
Time Before: 0.03257 seconds
Time After: 0.04046 seconds
Time Taken: 0.00789 seconds
Time Before: 0.05079 seconds
Time After: 0.05102 seconds
Time Before: 0.05363 seconds
Time After: 0.05490 seconds
Time Before: 0.05009 seconds
Time After: 0.05516 seconds
Time Taken: 0.00507 seconds
Time Before: 0.08264 seconds
Time After: 0.08282 seconds
Time Before: 0.10012 seconds
Time After: 0.10142 seconds
Time Before: 0.11740 seconds
Time After: 0.11758 seconds
Time Before: 0.12047 seconds
Time After: 0.12196 seconds
UPDATE session SET lastactivity = 1776878542, location = '/forums/private.php?do=newpm&explain=1&u=64831', badlocation = 1 WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.14075 seconds
Time After: 0.14116 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
