Time Before: 0.00226 seconds
Time After: 0.00291 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00301 seconds
Time After: 0.00341 seconds
Time Before: 0.00365 seconds
Time After: 0.00378 seconds
Time Before: 0.00474 seconds
Time After: 0.00698 seconds
Time Taken: 0.00225 seconds
Time Before: 0.00385 seconds
Time After: 0.01201 seconds
Time Taken: 0.00816 seconds
Time Before: 0.01380 seconds
Time After: 0.01428 seconds
Time Before: 0.01749 seconds
Time After: 0.01866 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01317 seconds
Time After: 0.01889 seconds
Time Taken: 0.00572 seconds
Time Before: 0.02443 seconds
Time After: 0.02456 seconds
Time Before: 0.02649 seconds
Time After: 0.02832 seconds
Time Taken: 0.00183 seconds
End call of global.php: 0.030030012130737
Time Before: 0.03158 seconds
Time After: 0.03174 seconds
Time Before: 0.03417 seconds
Time After: 0.03566 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=64946', badlocation = 1
Time Before: 0.04889 seconds
Time After: 0.04931 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.047980070114136 seconds with 9 queries, spending 0.0084431171417236 doing MySQL queries and 0.039536952972412 doing PHP things.
