Time Before: 0.00136 seconds
Time After: 0.00181 seconds
Time Before: 0.00188 seconds
Time After: 0.00244 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00268 seconds
Time After: 0.00280 seconds
Time Before: 0.00349 seconds
Time After: 0.00647 seconds
Time Taken: 0.00299 seconds
Time Before: 0.00285 seconds
Time After: 0.00987 seconds
Time Taken: 0.00702 seconds
Time Before: 0.01186 seconds
Time After: 0.01236 seconds
Time Before: 0.01483 seconds
Time After: 0.01611 seconds
Time Before: 0.01121 seconds
Time After: 0.01629 seconds
Time Taken: 0.00508 seconds
Time Before: 0.02170 seconds
Time After: 0.02192 seconds
Time Before: 0.02403 seconds
Time After: 0.02531 seconds
Time Before: 0.02821 seconds
Time After: 0.02842 seconds
Time Before: 0.03047 seconds
Time After: 0.03192 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=64977', badlocation = 1 WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.04422 seconds
Time After: 0.04455 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
