Time Before: 0.01685 seconds
Time After: 0.02127 seconds
Time Taken: 0.00442 seconds
Time Before: 0.02135 seconds
Time After: 0.02182 seconds
Time Before: 0.02207 seconds
Time After: 0.02222 seconds
Time Before: 0.02302 seconds
Time After: 0.02533 seconds
Time Taken: 0.00231 seconds
Time Before: 0.02229 seconds
Time After: 0.02947 seconds
Time Taken: 0.00718 seconds
Time Before: 0.03631 seconds
Time After: 0.03670 seconds
Time Before: 0.03945 seconds
Time After: 0.04100 seconds
Time Taken: 0.00154 seconds
Time Before: 0.03565 seconds
Time After: 0.04122 seconds
Time Taken: 0.00557 seconds
Time Before: 0.06622 seconds
Time After: 0.06638 seconds
Time Before: 0.08485 seconds
Time After: 0.08614 seconds
End call of global.php: 0.088419914245605
Time Before: 0.09260 seconds
Time After: 0.09279 seconds
Time Before: 0.09536 seconds
Time After: 0.09681 seconds
SET lastactivity = 1783101686, location = '/forums/private.php?do=newpm&explain=1&u=65000'
Time Before: 0.11756 seconds
Time After: 0.11795 seconds
Memory Before: 4,289.125 KB
Memory After: 4,289.352 KB
Page generated in 0.11654305458069 seconds with 9 queries, spending 0.0083353519439697 doing MySQL queries and 0.10820770263672 doing PHP things.
