Time Before: 0.01457 seconds
Time After: 0.02153 seconds
Time Taken: 0.00695 seconds
Time Before: 0.02162 seconds
Time After: 0.02206 seconds
Time Before: 0.02231 seconds
Time After: 0.02252 seconds
Time Before: 0.02327 seconds
Time After: 0.02594 seconds
Time Taken: 0.00267 seconds
Time Before: 0.02258 seconds
Time After: 0.03026 seconds
Time Taken: 0.00768 seconds
Time Before: 0.03551 seconds
Time After: 0.03598 seconds
Time Before: 0.03971 seconds
Time After: 0.04093 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.03481 seconds
Time After: 0.04119 seconds
Time Taken: 0.00638 seconds
Memory After: 2,261.836 KB
Time Before: 0.06706 seconds
Time After: 0.06720 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.08101 seconds
Time After: 0.08233 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.08933 seconds
Time After: 0.08949 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.09220 seconds
Time After: 0.09487 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789146822, location = '/forums/private.php?do=newpm&explain=1&u=65019', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.11690 seconds
Time After: 0.11726 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
