Time Before: 0.00147 seconds
Time After: 0.00192 seconds
Time Before: 0.00200 seconds
Time After: 0.00245 seconds
Time Before: 0.00268 seconds
Time After: 0.00280 seconds
Time Before: 0.00376 seconds
Time After: 0.00635 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00287 seconds
Time After: 0.01070 seconds
Time Taken: 0.00783 seconds
Time Before: 0.01270 seconds
Time After: 0.01313 seconds
Time Before: 0.01574 seconds
Time After: 0.01691 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01193 seconds
Time After: 0.01709 seconds
Time Taken: 0.00515 seconds
Memory After: 2,261.719 KB
Time Before: 0.02229 seconds
Time After: 0.02240 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02426 seconds
Time After: 0.02555 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.02832 seconds
Time After: 0.02848 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03042 seconds
Time After: 0.03185 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=65053' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04550 seconds
Time After: 0.04582 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
