Time Before: 0.00154 seconds
Time After: 0.00208 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00218 seconds
Time After: 0.00266 seconds
Time Before: 0.00293 seconds
Time After: 0.00304 seconds
Time Before: 0.00386 seconds
Time After: 0.00681 seconds
Time Taken: 0.00295 seconds
Time Before: 0.00312 seconds
Time After: 0.01115 seconds
Time Taken: 0.00802 seconds
Time Before: 0.01306 seconds
Time After: 0.01354 seconds
Time Before: 0.01619 seconds
Time After: 0.01757 seconds
Time Taken: 0.00137 seconds
Time Before: 0.01234 seconds
Time After: 0.01781 seconds
Time Taken: 0.00548 seconds
Time Before: 0.02488 seconds
Time After: 0.02505 seconds
Time Before: 0.02765 seconds
Time After: 0.02924 seconds
Time Taken: 0.00159 seconds
End call of global.php: 0.031585931777954
Time Before: 0.03280 seconds
Time After: 0.03297 seconds
Time Before: 0.03513 seconds
Time After: 0.03660 seconds
SET lastactivity = 1789042009, location = '/forums/private.php?do=newpm&explain=1&u=65100', badlocation = 1
Time Before: 0.04958 seconds
Time After: 0.04984 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.048628807067871 seconds with 9 queries, spending 0.0090568065643311 doing MySQL queries and 0.03957200050354 doing PHP things.
