Time Before: 0.00148 seconds
Time After: 0.00200 seconds
Time Before: 0.00207 seconds
Time After: 0.00259 seconds
Time Before: 0.00285 seconds
Time After: 0.00299 seconds
Time Before: 0.00366 seconds
Time After: 0.00673 seconds
Time Taken: 0.00307 seconds
Time Before: 0.00303 seconds
Time After: 0.01026 seconds
Time Taken: 0.00722 seconds
Time Before: 0.01218 seconds
Time After: 0.01263 seconds
Time Before: 0.01507 seconds
Time After: 0.01628 seconds
Time Before: 0.01153 seconds
Time After: 0.01646 seconds
Time Taken: 0.00493 seconds
Time Before: 0.02328 seconds
Time After: 0.02346 seconds
Time Before: 0.02544 seconds
Time After: 0.02677 seconds
Time Taken: 0.00133 seconds
End call of global.php: 0.028755903244019
Time Before: 0.03011 seconds
Time After: 0.03031 seconds
Time Before: 0.03302 seconds
Time After: 0.03449 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=6528'
Time Before: 0.05094 seconds
Time After: 0.05120 seconds
Memory Before: 4,287.719 KB
Memory After: 4,287.969 KB
Memory Used: 0.250 KB
Page generated in 0.049835920333862 seconds with 9 queries, spending 0.0088305473327637 doing MySQL queries and 0.041005373001099 doing PHP things.
