Time Before: 0.00376 seconds
Time After: 0.00442 seconds
Time Taken: 0.00066 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.00453 seconds
Time After: 0.00495 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.00519 seconds
Time After: 0.00534 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.00623 seconds
Time After: 0.00897 seconds
Time Taken: 0.00274 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.00542 seconds
Time After: 0.01414 seconds
Time Taken: 0.00872 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.01639 seconds
Time After: 0.01676 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.01945 seconds
Time After: 0.02081 seconds
Time Taken: 0.00136 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.01561 seconds
Time After: 0.02105 seconds
Time Taken: 0.00544 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.02923 seconds
Time After: 0.02944 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.03838 seconds
Time After: 0.03965 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
Time Before: 0.04918 seconds
Time After: 0.04933 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.05192 seconds
Time After: 0.05336 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=65513', badlocation = 1 WHERE sessionhash = 'cf9a7d249f143a0ae3eb7b561aa7a27f'
Time Before: 0.06957 seconds
Time After: 0.06989 seconds
Memory Before: 5,998.492 KB
Memory After: 5,998.711 KB
