Time Before: 0.00321 seconds
Time After: 0.00409 seconds
Time Taken: 0.00089 seconds
Time Before: 0.00419 seconds
Time After: 0.00482 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00508 seconds
Time After: 0.00520 seconds
Time Before: 0.00592 seconds
Time After: 0.00843 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00525 seconds
Time After: 0.01175 seconds
Time Taken: 0.00651 seconds
Time Before: 0.01370 seconds
Time After: 0.01425 seconds
Time Taken: 0.00055 seconds
Time Before: 0.01751 seconds
Time After: 0.01880 seconds
Time Before: 0.01299 seconds
Time After: 0.01898 seconds
Time Taken: 0.00599 seconds
Time Before: 0.02479 seconds
Time After: 0.02491 seconds
Time Before: 0.02673 seconds
Time After: 0.02797 seconds
End call of global.php: 0.029583215713501
Time Before: 0.03084 seconds
Time After: 0.03098 seconds
Time Before: 0.03301 seconds
Time After: 0.03449 seconds
SET lastactivity = 1785284368, location = '/forums/private.php?do=newpm&explain=1&u=65533'
Time Before: 0.04965 seconds
Time After: 0.05002 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.048391103744507 seconds with 9 queries, spending 0.0084640979766846 doing MySQL queries and 0.039927005767822 doing PHP things.
