Time Before: 0.00221 seconds
Time After: 0.00277 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00287 seconds
Time After: 0.00336 seconds
Time Before: 0.00360 seconds
Time After: 0.00374 seconds
Time Before: 0.00462 seconds
Time After: 0.00743 seconds
Time Taken: 0.00280 seconds
Time Before: 0.00380 seconds
Time After: 0.01264 seconds
Time Taken: 0.00884 seconds
Time Before: 0.01489 seconds
Time After: 0.01510 seconds
Time Before: 0.01754 seconds
Time After: 0.01871 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01429 seconds
Time After: 0.01893 seconds
Time Taken: 0.00464 seconds
Time Before: 0.02538 seconds
Time After: 0.02555 seconds
Time Before: 0.02796 seconds
Time After: 0.02926 seconds
End call of global.php: 0.031816005706787
Time Before: 0.03342 seconds
Time After: 0.03363 seconds
Time Before: 0.03584 seconds
Time After: 0.03731 seconds
SET lastactivity = 1776744395, location = '/forums/private.php?do=newpm&explain=1&u=65632', badlocation = 1
Time Before: 0.04970 seconds
Time After: 0.05005 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.048801183700562 seconds with 9 queries, spending 0.0083158016204834 doing MySQL queries and 0.040485382080078 doing PHP things.
