Time Before: 0.00334 seconds
Time After: 0.00388 seconds
Time Taken: 0.00054 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.00395 seconds
Time After: 0.00436 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.00458 seconds
Time After: 0.00478 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.00543 seconds
Time After: 0.00821 seconds
Time Taken: 0.00278 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.00482 seconds
Time After: 0.01332 seconds
Time Taken: 0.00849 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.01590 seconds
Time After: 0.01629 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.01901 seconds
Time After: 0.02030 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.01503 seconds
Time After: 0.02058 seconds
Time Taken: 0.00554 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.02826 seconds
Time After: 0.02841 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.03594 seconds
Time After: 0.03718 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.038838863372803
Time Before: 0.04631 seconds
Time After: 0.04645 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.04966 seconds
Time After: 0.05109 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=65703'
WHERE sessionhash = 'fb8546df1d172120a5a514bbe0406f9a'
Time Before: 0.06504 seconds
Time After: 0.06532 seconds
Memory Before: 5,998.203 KB
Memory After: 5,998.445 KB
Page generated in 0.064045906066895 seconds with 9 queries, spending 0.0083339214324951 doing MySQL queries and 0.055711984634399 doing PHP things.
