Time Before: 0.01179 seconds
Time After: 0.01950 seconds
Time Taken: 0.00771 seconds
Time Before: 0.01960 seconds
Time After: 0.02006 seconds
Time Before: 0.02033 seconds
Time After: 0.02046 seconds
Time Before: 0.02127 seconds
Time After: 0.02403 seconds
Time Taken: 0.00275 seconds
Time Before: 0.02052 seconds
Time After: 0.02822 seconds
Time Before: 0.03939 seconds
Time After: 0.03982 seconds
Time Before: 0.04302 seconds
Time After: 0.04419 seconds
Time Taken: 0.00117 seconds
Time Before: 0.03871 seconds
Time After: 0.04443 seconds
Time Taken: 0.00572 seconds
Time Before: 0.06460 seconds
Time After: 0.06474 seconds
Time Before: 0.08712 seconds
Time After: 0.08835 seconds
Time Before: 0.09822 seconds
Time After: 0.09840 seconds
Time Before: 0.10097 seconds
Time After: 0.10245 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=65714' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.12068 seconds
Time After: 0.12092 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
