Time Before: 0.01722 seconds
Time After: 0.02339 seconds
Time Taken: 0.00617 seconds
Time Before: 0.02351 seconds
Time After: 0.02481 seconds
Time Before: 0.02542 seconds
Time After: 0.02559 seconds
Time Before: 0.02648 seconds
Time After: 0.03118 seconds
Time Taken: 0.00470 seconds
Time Before: 0.02567 seconds
Time After: 0.03605 seconds
Time Taken: 0.01038 seconds
Memory After: 1,641.789 KB
Memory Used: 1,080.992 KB
Time Before: 0.04365 seconds
Time After: 0.04405 seconds
Memory Before: 2,136.734 KB
Memory After: 2,137.352 KB
Time Before: 0.04699 seconds
Time After: 0.04836 seconds
Time Taken: 0.00137 seconds
Memory Before: 2,148.914 KB
Memory After: 2,148.773 KB
Time Before: 0.04283 seconds
Time After: 0.04873 seconds
Time Taken: 0.00590 seconds
Memory Before: 2,128.914 KB
Memory After: 2,261.813 KB
Memory Used: 132.898 KB
Time Before: 0.08366 seconds
Time After: 0.08383 seconds
Memory Before: 2,815.375 KB
Memory After: 2,815.891 KB
Time Before: 0.09694 seconds
Time After: 0.09824 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.10457 seconds
Time After: 0.10474 seconds
Memory Before: 3,540.336 KB
Memory After: 3,540.766 KB
Time Before: 0.10753 seconds
Time After: 0.10900 seconds
Memory Before: 3,821.891 KB
Memory After: 3,823.578 KB
UPDATE session SET lastactivity = 1788981345, location = '/forums/private.php?do=newpm&explain=1&u=65726', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.12840 seconds
Time After: 0.12868 seconds
Memory Before: 4,287.813 KB
Memory After: 4,288.023 KB
