Time Before: 0.02794 seconds
Time After: 0.03748 seconds
Time Taken: 0.00954 seconds
Time Before: 0.03759 seconds
Time After: 0.03855 seconds
Time Taken: 0.00097 seconds
Time Before: 0.03879 seconds
Time After: 0.03894 seconds
Time Before: 0.03990 seconds
Time After: 0.04291 seconds
Time Taken: 0.00301 seconds
Time Before: 0.03902 seconds
Time After: 0.04717 seconds
Time Taken: 0.00815 seconds
Time Before: 0.05266 seconds
Time After: 0.05286 seconds
Time Before: 0.05452 seconds
Time After: 0.05580 seconds
Time Before: 0.05197 seconds
Time After: 0.05603 seconds
Time Taken: 0.00406 seconds
Time Before: 0.11294 seconds
Time After: 0.11323 seconds
Time Before: 0.14868 seconds
Time After: 0.14991 seconds
Time Before: 0.15991 seconds
Time After: 0.16007 seconds
Time Before: 0.16276 seconds
Time After: 0.16421 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=65842', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.18461 seconds
Time After: 0.18490 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
