Time Before: 0.01359 seconds
Time After: 0.01712 seconds
Time Taken: 0.00353 seconds
Time Before: 0.01720 seconds
Time After: 0.01774 seconds
Time Taken: 0.00055 seconds
Time Before: 0.01800 seconds
Time After: 0.01815 seconds
Time Before: 0.01900 seconds
Time After: 0.02188 seconds
Time Taken: 0.00288 seconds
Time Before: 0.01822 seconds
Time After: 0.02708 seconds
Time Taken: 0.00886 seconds
Time Before: 0.03331 seconds
Time After: 0.03366 seconds
Time Before: 0.03597 seconds
Time After: 0.03723 seconds
Time Before: 0.03261 seconds
Time After: 0.03747 seconds
Time Taken: 0.00486 seconds
Time Before: 0.05710 seconds
Time After: 0.05728 seconds
Time Before: 0.06539 seconds
Time After: 0.06665 seconds
End call of global.php: 0.069288015365601
Time Before: 0.07530 seconds
Time After: 0.07549 seconds
Time Before: 0.07814 seconds
Time After: 0.07958 seconds
SET lastactivity = 1776553218, location = '/forums/private.php?do=newpm&explain=1&u=65849', badlocation = 1
Time Before: 0.09956 seconds
Time After: 0.09987 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.09844708442688 seconds with 9 queries, spending 0.0085573196411133 doing MySQL queries and 0.089889764785767 doing PHP things.
