Time Before: 0.01134 seconds
Time After: 0.01461 seconds
Time Taken: 0.00327 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.01471 seconds
Time After: 0.01517 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.01542 seconds
Time After: 0.01556 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.01635 seconds
Time After: 0.01895 seconds
Time Taken: 0.00260 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.01564 seconds
Time After: 0.02455 seconds
Time Taken: 0.00891 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.03072 seconds
Time After: 0.03108 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.03370 seconds
Time After: 0.03488 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.02989 seconds
Time After: 0.03514 seconds
Time Taken: 0.00525 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.05789 seconds
Time After: 0.05803 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.06786 seconds
Time After: 0.06910 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
End call of global.php: 0.071437835693359
Time Before: 0.07536 seconds
Time After: 0.07560 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.07791 seconds
Time After: 0.07934 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=65861'
Time Before: 0.09512 seconds
Time After: 0.10079 seconds
Time Taken: 0.00568 seconds
Memory Before: 4,918.352 KB
Memory After: 4,918.594 KB
Page generated in 0.094058990478516 seconds with 9 queries, spending 0.013473272323608 doing MySQL queries and 0.080585718154907 doing PHP things.
