Time Before: 0.00152 seconds
Time After: 0.00218 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00225 seconds
Time After: 0.00269 seconds
Time Before: 0.00290 seconds
Time After: 0.00308 seconds
Time Before: 0.00376 seconds
Time After: 0.00594 seconds
Time Taken: 0.00219 seconds
Time Before: 0.00314 seconds
Time After: 0.00947 seconds
Time Taken: 0.00633 seconds
Time Before: 0.01199 seconds
Time After: 0.01241 seconds
Time Before: 0.01397 seconds
Time After: 0.01519 seconds
Time Before: 0.01140 seconds
Time After: 0.01544 seconds
Time Taken: 0.00404 seconds
Time Before: 0.02729 seconds
Time After: 0.02746 seconds
Time Before: 0.02975 seconds
Time After: 0.03104 seconds
Time Before: 0.03552 seconds
Time After: 0.03572 seconds
Time Before: 0.03864 seconds
Time After: 0.04015 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1776690107, location = '/forums/private.php?do=newpm&explain=1&u=65922' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.05713 seconds
Time After: 0.05750 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
