Time Before: 0.00213 seconds
Time After: 0.00295 seconds
Time Taken: 0.00083 seconds
Time Before: 0.00307 seconds
Time After: 0.00356 seconds
Time Before: 0.00379 seconds
Time After: 0.00429 seconds
Time Before: 0.00540 seconds
Time After: 0.00758 seconds
Time Taken: 0.00218 seconds
Time Before: 0.00434 seconds
Time After: 0.01097 seconds
Time Taken: 0.00663 seconds
Time Before: 0.01328 seconds
Time After: 0.01364 seconds
Time Before: 0.01607 seconds
Time After: 0.01730 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01269 seconds
Time After: 0.01746 seconds
Time Taken: 0.00478 seconds
Memory After: 2,261.836 KB
Time Before: 0.02480 seconds
Time After: 0.02497 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02716 seconds
Time After: 0.02845 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.03179 seconds
Time After: 0.03198 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03439 seconds
Time After: 0.03599 seconds
Time Taken: 0.00160 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789029107, location = '/forums/private.php?do=newpm&explain=1&u=65987' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05022 seconds
Time After: 0.05059 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
