Time Before: 0.00180 seconds
Time After: 0.00240 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00250 seconds
Time After: 0.00310 seconds
Time Before: 0.00332 seconds
Time After: 0.00344 seconds
Time Before: 0.00427 seconds
Time After: 0.00690 seconds
Time Taken: 0.00264 seconds
Time Before: 0.00349 seconds
Time After: 0.01033 seconds
Time Taken: 0.00685 seconds
Time Before: 0.01216 seconds
Time After: 0.01263 seconds
Time Before: 0.01430 seconds
Time After: 0.01550 seconds
Time Before: 0.01158 seconds
Time After: 0.01572 seconds
Time Taken: 0.00414 seconds
Time Before: 0.02294 seconds
Time After: 0.02313 seconds
Time Before: 0.02534 seconds
Time After: 0.02656 seconds
Time Before: 0.02983 seconds
Time After: 0.02996 seconds
Time Before: 0.03197 seconds
Time After: 0.03338 seconds
UPDATE session SET lastactivity = 1785399887, location = '/forums/private.php?do=newpm&explain=1&u=66007', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.04566 seconds
Time After: 0.04595 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
