Time Before: 0.02396 seconds
Time After: 0.03104 seconds
Time Taken: 0.00708 seconds
Time Before: 0.03114 seconds
Time After: 0.03160 seconds
Time Before: 0.03191 seconds
Time After: 0.03207 seconds
Time Before: 0.03287 seconds
Time After: 0.03540 seconds
Time Taken: 0.00253 seconds
Time Before: 0.03214 seconds
Time After: 0.03922 seconds
Time Before: 0.04456 seconds
Time After: 0.04502 seconds
Time Before: 0.04752 seconds
Time After: 0.04874 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04398 seconds
Time After: 0.04891 seconds
Time Taken: 0.00493 seconds
Memory After: 2,261.719 KB
Time Before: 0.09199 seconds
Time After: 0.09215 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.11062 seconds
Time After: 0.11187 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.11424493789673
Time Before: 0.12695 seconds
Time After: 0.12717 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.12987 seconds
Time After: 0.13132 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=66089'
Time Before: 0.14800 seconds
Time After: 0.14828 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.14700698852539 seconds with 9 queries, spending 0.0081808567047119 doing MySQL queries and 0.13882613182068 doing PHP things.
