Time Before: 0.01024 seconds
Time After: 0.01407 seconds
Time Taken: 0.00383 seconds
Time Before: 0.01419 seconds
Time After: 0.01464 seconds
Time Before: 0.01489 seconds
Time After: 0.01501 seconds
Time Before: 0.01594 seconds
Time After: 0.01808 seconds
Time Taken: 0.00214 seconds
Time Before: 0.01509 seconds
Time After: 0.02172 seconds
Time Taken: 0.00663 seconds
Time Before: 0.02727 seconds
Time After: 0.02769 seconds
Time Before: 0.03103 seconds
Time After: 0.03224 seconds
Time Before: 0.02648 seconds
Time After: 0.03249 seconds
Time Taken: 0.00601 seconds
Time Before: 0.04799 seconds
Time After: 0.04812 seconds
Time Before: 0.05765 seconds
Time After: 0.05891 seconds
End call of global.php: 0.061065196990967
Time Before: 0.06561 seconds
Time After: 0.06580 seconds
Time Before: 0.06900 seconds
Time After: 0.07047 seconds
SET lastactivity = 1785292197, location = '/forums/private.php?do=newpm&explain=1&u=66098'
Time Before: 0.08727 seconds
Time After: 0.08754 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.086233139038086 seconds with 9 queries, spending 0.0076649188995361 doing MySQL queries and 0.07856822013855 doing PHP things.
