Time Before: 0.00843 seconds
Time After: 0.01047 seconds
Time Taken: 0.00204 seconds
Time Before: 0.01056 seconds
Time After: 0.01101 seconds
Time Before: 0.01122 seconds
Time After: 0.01145 seconds
Time Before: 0.01224 seconds
Time After: 0.01446 seconds
Time Taken: 0.00221 seconds
Time Before: 0.01150 seconds
Time After: 0.01908 seconds
Time Taken: 0.00758 seconds
Time Before: 0.02296 seconds
Time After: 0.02342 seconds
Time Before: 0.02617 seconds
Time After: 0.02736 seconds
Time Before: 0.02228 seconds
Time After: 0.02754 seconds
Time Taken: 0.00526 seconds
Time Before: 0.03982 seconds
Time After: 0.03997 seconds
Time Before: 0.04729 seconds
Time After: 0.04860 seconds
Time Taken: 0.00131 seconds
Time Before: 0.05386 seconds
Time After: 0.05400 seconds
Time Before: 0.05740 seconds
Time After: 0.05900 seconds
Time Taken: 0.00159 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=66110' WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.08013 seconds
Time After: 0.08040 seconds
Memory Before: 4,911.656 KB
Memory After: 4,911.898 KB
