Time Before: 0.02297 seconds
Time After: 0.03089 seconds
Time Taken: 0.00793 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.03104 seconds
Time After: 0.03152 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.03180 seconds
Time After: 0.03204 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.03281 seconds
Time After: 0.03544 seconds
Time Taken: 0.00263 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.03212 seconds
Time After: 0.04111 seconds
Time Taken: 0.00899 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.05056 seconds
Time After: 0.05163 seconds
Time Taken: 0.00108 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.05524 seconds
Time After: 0.05656 seconds
Time Taken: 0.00132 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.04926 seconds
Time After: 0.05683 seconds
Time Taken: 0.00758 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.09821 seconds
Time After: 0.09837 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.31516 seconds
Time After: 0.31651 seconds
Time Taken: 0.00136 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
Time Before: 0.33989 seconds
Time After: 0.34004 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.34617 seconds
Time After: 0.34768 seconds
Time Taken: 0.00151 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
UPDATE session SET lastactivity = 1772693277, location = '/forums/private.php?do=newpm&explain=1&u=66126', badlocation = 1 WHERE sessionhash = 'c9ecef9835dff112a7666634a7a1b42a'
Time Before: 0.37287 seconds
Time After: 0.37335 seconds
Memory Before: 5,998.055 KB
Memory After: 5,998.250 KB
Memory Used: 0.195 KB
