Time Before: 0.00139 seconds
Time After: 0.00187 seconds
Time Before: 0.00194 seconds
Time After: 0.00241 seconds
Time Before: 0.00263 seconds
Time After: 0.00279 seconds
Time Before: 0.00336 seconds
Time After: 0.00563 seconds
Time Taken: 0.00227 seconds
Time Before: 0.00284 seconds
Time After: 0.00902 seconds
Time Taken: 0.00618 seconds
Time Before: 0.01082 seconds
Time After: 0.01114 seconds
Time Before: 0.01356 seconds
Time After: 0.01477 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01032 seconds
Time After: 0.01493 seconds
Time Taken: 0.00461 seconds
Memory After: 2,261.836 KB
Time Before: 0.02008 seconds
Time After: 0.02026 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02276 seconds
Time After: 0.02399 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.02648401260376
Time Before: 0.02779 seconds
Time After: 0.02791 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03015 seconds
Time After: 0.03162 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788912487, location = '/forums/private.php?do=newpm&explain=1&u=66149'
Time Before: 0.04745 seconds
Time After: 0.04787 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.046511888504028 seconds with 9 queries, spending 0.0078492164611816 doing MySQL queries and 0.038662672042847 doing PHP things.
