Time Before: 0.01703 seconds
Time After: 0.02525 seconds
Time Taken: 0.00821 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02535 seconds
Time After: 0.02576 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02605 seconds
Time After: 0.02620 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02697 seconds
Time After: 0.02886 seconds
Time Taken: 0.00189 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02629 seconds
Time After: 0.03355 seconds
Time Taken: 0.00726 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04504 seconds
Time After: 0.04542 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04668 seconds
Time After: 0.04787 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.04440 seconds
Time After: 0.04807 seconds
Time Taken: 0.00367 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.10368 seconds
Time After: 0.10389 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.16631 seconds
Time After: 0.16762 seconds
Time Taken: 0.00131 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.16989398002625
Time Before: 0.19673 seconds
Time After: 0.19693 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.19967 seconds
Time After: 0.20112 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=66194'
WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.23006 seconds
Time After: 0.23032 seconds
Memory Before: 5,997.453 KB
Memory After: 5,997.695 KB
Page generated in 0.22895503044128 seconds with 9 queries, spending 0.0074546337127686 doing MySQL queries and 0.22150039672852 doing PHP things.
