Time Before: 0.02740 seconds
Time After: 0.03700 seconds
Time Taken: 0.00960 seconds
Time Before: 0.03709 seconds
Time After: 0.03753 seconds
Time Before: 0.03775 seconds
Time After: 0.03788 seconds
Time Before: 0.03877 seconds
Time After: 0.04170 seconds
Time Taken: 0.00294 seconds
Time Before: 0.03798 seconds
Time After: 0.04581 seconds
Time Taken: 0.00783 seconds
Time Before: 0.05900 seconds
Time After: 0.05944 seconds
Time Before: 0.06196 seconds
Time After: 0.06340 seconds
Time Before: 0.05792 seconds
Time After: 0.06367 seconds
Time Taken: 0.00575 seconds
Time Before: 0.11223 seconds
Time After: 0.11236 seconds
Time Before: 0.12873 seconds
Time After: 0.12997 seconds
Time Before: 0.14120 seconds
Time After: 0.14138 seconds
Time Before: 0.14436 seconds
Time After: 0.14587 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1776826529, location = '/forums/private.php?do=newpm&explain=1&u=66203' WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.16540 seconds
Time After: 0.16568 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
