Time Before: 0.00211 seconds
Time After: 0.00259 seconds
Time Before: 0.00266 seconds
Time After: 0.00301 seconds
Time Before: 0.00317 seconds
Time After: 0.00327 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00389 seconds
Time After: 0.00628 seconds
Time Taken: 0.00239 seconds
Time Before: 0.00332 seconds
Time After: 0.00974 seconds
Time Taken: 0.00643 seconds
Time Before: 0.01164 seconds
Time After: 0.01207 seconds
Time Before: 0.01498 seconds
Time After: 0.01617 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01108 seconds
Time After: 0.01643 seconds
Time Taken: 0.00535 seconds
Memory After: 2,261.719 KB
Time Before: 0.02230 seconds
Time After: 0.02248 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02422 seconds
Time After: 0.02540 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.027094841003418
Time Before: 0.02817 seconds
Time After: 0.02832 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03028 seconds
Time After: 0.03169 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=66235'
Time Before: 0.04386 seconds
Time After: 0.04440 seconds
Time Taken: 0.00054 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.042983055114746 seconds with 9 queries, spending 0.0079224109649658 doing MySQL queries and 0.03506064414978 doing PHP things.
