Time Before: 0.00231 seconds
Time After: 0.00291 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00298 seconds
Time After: 0.00333 seconds
Time Before: 0.00353 seconds
Time After: 0.00367 seconds
Time Before: 0.00446 seconds
Time After: 0.00693 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00374 seconds
Time After: 0.01114 seconds
Time Taken: 0.00740 seconds
Time Before: 0.01301 seconds
Time After: 0.01340 seconds
Time Before: 0.01623 seconds
Time After: 0.01754 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01240 seconds
Time After: 0.01780 seconds
Time Taken: 0.00540 seconds
Time Before: 0.02426 seconds
Time After: 0.02441 seconds
Time Before: 0.02673 seconds
Time After: 0.02801 seconds
Time Before: 0.03194 seconds
Time After: 0.03208 seconds
Time Before: 0.03412 seconds
Time After: 0.03586 seconds
Time Taken: 0.00174 seconds
UPDATE session SET lastactivity = 1776684807, location = '/forums/private.php?do=newpm&explain=1&u=66329' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.05467 seconds
Time After: 0.05504 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
