Time Before: 0.02379 seconds
Time After: 0.02914 seconds
Time Taken: 0.00535 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.02924 seconds
Time After: 0.02963 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.03029 seconds
Time After: 0.03041 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.03124 seconds
Time After: 0.03451 seconds
Time Taken: 0.00328 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.03047 seconds
Time After: 0.03877 seconds
Time Taken: 0.00830 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.219 KB
Memory Used: 1,081.055 KB
Time Before: 0.04550 seconds
Time After: 0.04592 seconds
Memory Before: 2,758.023 KB
Memory After: 2,758.641 KB
Time Before: 0.04905 seconds
Time After: 0.05023 seconds
Memory Before: 2,770.078 KB
Memory After: 2,769.938 KB
Time Before: 0.04472 seconds
Time After: 0.05046 seconds
Time Taken: 0.00574 seconds
Memory Before: 2,750.172 KB
Memory After: 2,883.297 KB
Memory Used: 133.125 KB
Time Before: 0.09765 seconds
Time After: 0.09778 seconds
Memory Before: 3,436.438 KB
Memory After: 3,436.953 KB
Time Before: 0.11397 seconds
Time After: 0.11547 seconds
Time Taken: 0.00151 seconds
Memory Before: 3,524.234 KB
Memory After: 3,524.828 KB
Time Before: 0.12576 seconds
Time After: 0.12591 seconds
Memory Before: 4,162.117 KB
Memory After: 4,162.547 KB
Time Before: 0.12849 seconds
Time After: 0.13014 seconds
Time Taken: 0.00165 seconds
Memory Before: 4,443.680 KB
Memory After: 4,445.367 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=66401', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.14753 seconds
Time After: 0.14781 seconds
Memory Before: 4,921.977 KB
Memory After: 4,922.203 KB
