Time Before: 0.00166 seconds
Time After: 0.00228 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00235 seconds
Time After: 0.00275 seconds
Time Before: 0.00295 seconds
Time After: 0.00308 seconds
Time Before: 0.00384 seconds
Time After: 0.00639 seconds
Time Taken: 0.00255 seconds
Time Before: 0.00314 seconds
Time After: 0.00989 seconds
Time Taken: 0.00675 seconds
Time Before: 0.01171 seconds
Time After: 0.01211 seconds
Time Before: 0.01515 seconds
Time After: 0.01632 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01115 seconds
Time After: 0.01649 seconds
Time Taken: 0.00533 seconds
Time Before: 0.02176 seconds
Time After: 0.02195 seconds
Time Before: 0.02412 seconds
Time After: 0.02596 seconds
Time Taken: 0.00184 seconds
Time Before: 0.02897 seconds
Time After: 0.02910 seconds
Time Before: 0.03142 seconds
Time After: 0.03289 seconds
UPDATE session SET lastactivity = 1789045050, location = '/forums/private.php?do=newpm&explain=1&u=66697', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04588 seconds
Time After: 0.04615 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
