Time Before: 0.00172 seconds
Time After: 0.00219 seconds
Time Before: 0.00226 seconds
Time After: 0.00273 seconds
Time Before: 0.00300 seconds
Time After: 0.00322 seconds
Time Before: 0.00419 seconds
Time After: 0.00696 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00330 seconds
Time After: 0.01174 seconds
Time Taken: 0.00845 seconds
Time Before: 0.01408 seconds
Time After: 0.01454 seconds
Time Before: 0.01709 seconds
Time After: 0.01845 seconds
Time Taken: 0.00136 seconds
Time Before: 0.01328 seconds
Time After: 0.01873 seconds
Time Taken: 0.00544 seconds
Time Before: 0.02546 seconds
Time After: 0.02568 seconds
Time Before: 0.02808 seconds
Time After: 0.02943 seconds
Time Taken: 0.00135 seconds
End call of global.php: 0.031202077865601
Time Before: 0.03255 seconds
Time After: 0.03268 seconds
Time Before: 0.03482 seconds
Time After: 0.03636 seconds
Time Taken: 0.00154 seconds
SET lastactivity = 1789130615, location = '/forums/private.php?do=newpm&explain=1&u=6703', badlocation = 1
Time Before: 0.05043 seconds
Time After: 0.05129 seconds
Time Taken: 0.00087 seconds
Memory Before: 4,911.445 KB
Memory After: 4,911.656 KB
Page generated in 0.049510955810547 seconds with 9 queries, spending 0.0094003677368164 doing MySQL queries and 0.04011058807373 doing PHP things.
